C3 Frame Bracket - NCRS Discussion Boards
C3 Frame Bracket
  • Henry J.
    • November 1, 1999
    • 457
    C3 Frame Bracket
    My 68 L36 4-speed convertible has (what I believe to be) a replacement frame. On top of the left hand frame rail, just aft of the clutch cross-shaft bracket and forward of the No. 1 body mount there is another bracket, with two holes. This other bracket does nothing other than mystify me. Can anyone tell me what it's for? Thank you.
  • Henry J.
    • November 1, 1999
    • 457
    Re: C3 Frame Bracket - Addendum
    This bracket is depicted on the frame illustration appearing on page 28 of the current Corvette Central 1968-1982 Parts and Accessories Catalog 3E.
      Henry-----
      The bracket to which you refer is to mount the brake distribution and pressure differential mounting switch used for 1974-82 Corvettes. It's presence on your frame would indicate that your frame has been replaced with a 74-82 frame. Depending upon which of these years was used, a modest to considerable amount of work would have been necessary to convert the frame to a 1968 application.
      • Henry J.
        • November 1, 1999
        • 457
        Re: C3 Frame Bracket - Joe
        Joe, thank you once again for helping me out!
