Hello all, After completely restoring my 4 sp.'72, the final touch was to replace the pedal pads and gas pedal with new ones. The problem is that the new gas pedal is much larger than the old one and frequently gets in the way when going for the brake (can be unnerving at times). The old one was (I destroyed it trying to remove it) the perfect size and I assume it was the original. I called the supplier I got it from and explained the difference and they sent me the "right one" (you gessed it.....exactly the same one again). Could this be for an automatic? Is there a difference? Is the one I need discontinued? Any help would be appreciated.
Thanks, Bob Booth #33372
