Hello All -
Suddenly last week the high beam indicator lamp and both turn signal lamps on my '66 all lit up at the same time (dimly). The ammeter guage also began fluctuating between + and -. While troubleshooting the problem I found that I am getting 17vdc at the battery and the fuse box while the car is running. I replaced the voltage regulator but this did not correct the problem. Is the high voltage causing the lights to illuminate or is some kind of short causing excessive draw from the alternator? Could the alternator be the problem? It is a rebuilt unit and has been on the car for about a month. It was putting out about 14 vdc when I installed it. I'll be tearing into it this weekend and hope someone may be able to point me in the right direction. Thanks - P.J.
