Tach Needle bounce & PV? - NCRS Discussion Boards
  • David K.
    • August 31, 2002
    • 62
    Can anyone tell me what an acceptable tach needle bounce would be for a 1967 427/435 to pass the PV?
    I am not sure that I even have a bounce. When I accelerate rapidly and/or shift the needle may bounce around 500 rpm or so. When driving at a constant speed or accelerating smoothly the needle is very steady.
    If this is aproblem that would fail the PV, are there any suggestions to correct it?
    Thanks.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Tach Needle bounce & PV?
    no bounce at constant idle is what you want. the nature of the cable driven tack will have inherent bounce as rpm increases and decreases.good luck on the upcoming pv. mike
