C3 Bright Indicator Lamp
  • Gregory G.
    • August 1, 2001
    • 199
    Is the bulb replacement accessible from behind the dash,or does the speedometer need to be pulled?
    Greg
  • Tony H.
    • June 1, 1993
    • 537
    Re: C3 Bright Indicator Lamp
    Greg,
    I think it should be accessible without much removal. I'll check tonight on mine and respond tomorrow.
    Tony
      • 42936
      greg-----
      It's "accessible" if you can locate the socket by "feel"; you won't be able to see much unless you're a lilliputian.
      If getting at it should prove "unworkable" for you, then you need to pull the left side dash panel forward; you don't need to remove the speedometer head from the dash, though. Tip: if you go behind the dash for this or any other reason, replace ALL of the dash bulbs at the same time. These things are not very expensive and one is better off to "renew" all of them so as to avoid the need for "multiple incursions" behind the dash.
      • D S.
        • March 1, 2005
        • 1551
        My Corvette mechanic and proctologist both have small hands. Thank God.
