My 64 convertible pulls to the left when the brakes are applied. I can feel it through the steering wheel which indicates that it is a problem in the front brakes, from what I've been told a read about it is in the right front brake?
In the past 2 years I've replaced or rebuilt all wheel cylinders, replaced all the flexible rubber brake lines at each corner of the car, replaced all the brake spring hardware for all the brakes and installed new brake shoes both front and back, bled the brakes and adjusted them per the factory shop manual. The car did same thing before I did all this work. What could be causing the problem? I need to correct this before going to Salt Lake City in July.
James West
James West
