C-2 Oil Canister - NCRS Discussion Boards
C-2 Oil Canister
  • Don Z.
    • August 31, 1998
    • 254
    C-2 Oil Canister
    Looking to buy an original oil filter canister for my '66. The seller says it is for a '62. I thought there were 2 styles, 1 for the 50's and the 2nd style for about '62 thru '67.
    He says the length is 6 3/4". Sounds right. If it is from a '62 won't it fit my '66???? Thanks for any help
  • William C.
    • May 31, 1975
    • 6037
    Re: C-2 Oil Canister
    Yes, the 56-57 used a larger can. 62 is the same as 63-67
    Bill Clupper #618
    • Frank P.
      • April 1, 2005
      • 30
      '58-67 part # PF-141 just got my reconditioned original from Paragon..$125 beautiful silkscreening and finish.Only way to go in my opinion.
      • Brian M.
        • February 1, 1997
        • 1837
        Check in with Ken Hansen of OrinDales. He did 3 for me about a year ago and they were less thatn 125.00 I'm sure. They are perfect. He can also suply a correct cannister. Don't buy a repro cannister.
        Hansen2@bellsouth.net
        • Don Z.
          • August 31, 1998
          • 254
          Thanks everyone for the confirmation. Yes an original is the only way to go and I do already have Ken's name and have been in contact. Thank again
          • Kevin T.
            • August 31, 2002
            • 84
            Other than knowledge regarding originality, what is wrong with a repro cannister? It seems like a rather simple piece of metal that could easily be perfectly duplicated. - Kevin
            • Rob A.
              • December 1, 1991
              • 2126
              Kevin,
              I understand they work and look just fine, but made of thinner steel than originals.
