If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
What is the current recommendation for painting a C2. I know they were acrilic lacquer, but is there an acceptable substitute? No one in California will paint lacquer these days. Urathanes and base/clears are apparently forbidden for judging. So what do you use?
Also what is recommended for rust prevention on unpainted suspension parts?
Tim
Ask your painter if he can use single stage products. Several manufacuters make these and they can work in place of lacquer. Problems with them are that they go on glossy and need to be either dulled down by adding gloss retarder to the hood suround and door jams or need to be mechanically dulled after painting of the car. Would rather see a gloss modifier used to dull, it will look more natural and will be dull in all areas including the deep areas around the door hinges that you can not reach when trying to dull by hand. This coatings will show color if needed during judging. Not quite as durable as base coat/clear but better than lacquer.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
