Hi all.
I was trying to install my speaker with screen and bezel in my 62. I'm having a problem getting the nuts to grab the studs on the bezel. My speaker is a reproduction speaker.The bezel has a taper at the ends of the studs and they just stick through the nut. There is not enough stud for the nuts to catch.If I turn the nut around, it grabs. But thats not how it goes and you can't tighten it that way. Are there special thin nuts for the speaker? Is the bezel supposed to just lay snug on the dash pad or is it supposed to recess in the pad? Any help is appreciated on getting this speaker in.
Thanks....John
Thanks....John
