C2 1965 Headlight Bezel Attachment Repair - NCRS Discussion Boards
  • Louis T.
    • July 31, 2003
    • 282
    Re: C2 1965 Headlight Bezel Attachment Repair
    Sounds like a reasonable 'fix' path to me...short of replacing the HL bucket!
    • Wayne W.
      • April 30, 1982
      • 3605
      A small piece of sheet metal screwed or riveted to the stub with a hole in it works nicely.
      • Floyd #21606
        Louis, I had the same problem with one of my headlight bezels, I used JB Weld and built up a new tab,after the JB Weld cured I used a Dremal Tool to grind down the material to match the existing tab on the other side, put on a J Nut,
        reinstalled the bezel and screwed it in place. It's been there ever since.
        Hope this helps
        Floyd
        65 Fuelie
