C1 clock repair
  • paul bowers
    #1
    C1 clock repair
    I may try to have my 57 clock repaired, two co.s that advertise are (clocks by roger) and (D&M) does anyone what to comment on these two co.s, good or bad.
    or any other suggestions as to places where you have had good results thanks
    Paul
  • Stephen L.
    • June 1, 1984
    • 3109
    Re: C1 clock repair
    I had mine (C2) done by D&M. It works and looks good. He does a lot of instrument repair for all types of cars. I've been in his shop and he has a lot of work with repeat business.
    • Wayne P.
      • September 1, 1975
      • 1025
      Re: C1 clock repair
      Roger used to be good when he sat at the shows and worked on stuff. Now he is too big and sends the stuff off to be repaired by somebody else. I stopped using him after it took 9 months and countless calls to get a tach returned.
      • Dave S.
        • September 1, 1992
        • 2881
        Re: C1 clock repair
        Jerry at clockworks has done many clocks for me. Give him a try.
        • Ed Jennngs
          Re: C1 clock repair
          Clockworks will fix it for usually $40, and have a quick turn.
          • Rob Dame
            Re: C1 clock repair
            After I had my clock repaired with the original workings it was suggested that a 1 amp inline fuse be installed so that if the coil hung the fuse would blow instead of possibly causing a fire.I just made a pig-tail with an inline fuse holder that would plug between the harness and the clock. Easy to remove if the time came to have it judged. Rob
            • Eugene B.
              • June 1, 1988
              • 710
              Re: C1 clock repair
              Paul,
              I highly recommend Corvette Instrument Services in Florida. The owner is Roger Scott. (Not to be confused with Clocks by Roger). His telephone number is 561-691-2905.
              Roger did a beautiful job on the clock for my '65. He also repaired the odometers in my speedo unit.
              Gene
              • Donald O.
                • June 1, 1990
                • 1564
                Re: C1 clock repair
                Clockworks does a superlative job. They did my 67 and I love it.
                Clocks by Roger has done one for me before but never again.
                Don
                • Stephen J.
                  Infrequent User
                  • November 1, 1982
                  • 24
                  What's his contact number? *NM* *NM*
                  • Dave S.
                    • September 1, 1992
                    • 2881
                    clockwks@nnex.net *NM*
                      Re: C1 clock repair
                      The Clockworks (www.clockwks.com) has done several C1 clocks for me with excellent results (mechanical, not quartz, although they'll do quartz conversions too if you want).
                      Clockworks
                      • Rob Edwards
                        Another vote for clockworks
                        They did a great job on the clock in our '62, including an additional $15 for repair of the broken 12V terminal. Works like a charm for over a year now, guess it's time to unplug it.....
