C2 gas tank sending unit - NCRS Discussion Boards
  • Floyd #21606
    I purchased a "supposedly" made in the USA gas tank sending unit for my 1965 vette. When I installed it in the tank and put the retainer on I didn't have enough room to install my original wiring harness to the S and I terminals on the sending unit. Has anyone else had this problem? I have installed my original sending unit in my old tank and in my new correct repro tank with no problems, however my original unit finally died and I had to get a new one.
    If I have to purchase another sending unit, who has the best one that will install,connect and work correctly?
    Thanks in advance for any and all information.
    Floyd
    65 Fuelie
  • Jon #40768
    Re: C2 gas tank sending unit
    It is my impression that the units with yellow floats and screens are made by GM. I just bought two from Quanta. The first one was not soldered where the outlet tub passes through the baseplate. The second one was soldered and installed easily and works. I have only put in a 1/4 of a tank of gas, so I can not was how it reads when full.
    Jon
    • Floyd #21606
      Re: C2 gas tank sending unit - Thanks Jon *NM*
