Repro battery charge question - NCRS Discussion Boards
  • Garry Barnes
    I have a reproduction battery (bought from restoration battery) for my '56 and have had it on a battery minder system for several months now while doing a frame off. Periodically it seems as though one of the cells boils over and leaves water on top of the battery. It seems to always be the same cell. Am I headed for trouble with this battery or is this normal? I also don't want it to leak after getting the car back together and spraying battery water and acid all over the engine compartment. Any thoughts? Thanks.
    Garry
  • Craig S.
    • June 30, 1997
    • 2471
    Re: Repro battery charge question
    Garry - that would be acid not water on top of the battery....it is possible that cell has too high an acid level. If you can remove the cap and check compared to the other cells, I would. If high, draw some out with a syringe or suction unit of some sort. If the level looks Ok.......I would think about a different battery...it is not worth corrosion in the car.....Craig
    • Garry Barnes
      Craig, thanks for you response. I do have a gauge that draws up some of the fluid and is suppose to detect the level of acidity in the battery. I will try this and see what I can find. Do you think I should disconnect this battery minder in the meantime? The way these things cycle on and off, it shouldn't make a difference right?
      • Craig S.
        • June 30, 1997
        • 2471
        I would just disconnect it until you see if the cell level is too high. And, you are right, the specific gravity can be checked with the tool you mention, giving you an overall wellness state of the cells and charge...Craig
        • Ron Hambrecht
          Sounds like that cell was overfilled.
