Warning: Undefined array key 0 in .../vb/user.php on line 530
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530
Warning: Undefined array key 0 in .../vb/usercontext.php on line 221
Warning: Trying to access array offset on value of type null in .../vb/usercontext.php on line 221
1962 Corvette Birthdate -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have a 1962 Corvette with a serial number of 111753. I heard there is a web site to figure out the birthay of my Vette. From what I have read in the NCRS Pocket Spec Guide it is a May 1962 car. Is there a way to narrow down the date?
David
David - I think the key word is "extrapolate..."
...I believe, based on end of month info, my '62 11966 was built 05/30/62.
End of April VIN = 10519
End of May VIN = 12035
I would think your car will fit right in a small window of build opportunity...
David
Since there were 1516 Corvettes built in May and your vin is 282 from the end I would say it built 2-4 days before the end of the month. Someone with a birthday book will probably narrow it down even further.
The birthday calender on the C1 registry website comes up with Dec. 31 1953, a bit off I'd say. Hope this helps
PS The birthday book is available from the NCRS store, mine is on its way.
