Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 1962 Corvette Birthdate - NCRS Discussion Boards
  • David J.
    Infrequent User
    • May 31, 2000
    • 28
    I have a 1962 Corvette with a serial number of 111753. I heard there is a web site to figure out the birthay of my Vette. From what I have read in the NCRS Pocket Spec Guide it is a May 1962 car. Is there a way to narrow down the date?
    David
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    David - I think the key word is "extrapolate..."
    ...I believe, based on end of month info, my '62 11966 was built 05/30/62.
    End of April VIN = 10519
    End of May VIN = 12035
    I would think your car will fit right in a small window of build opportunity...
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12695
      Re: 1962 Corvette Birthdate
      There is a birthday calculation function available now on the C1 Registry (http://www.c1registry.com).
      greetings,
      Rob.
      Rob.
      NCRS Software Developer
      • Terry D.
        • May 31, 1987
        • 2690
        David
        Since there were 1516 Corvettes built in May and your vin is 282 from the end I would say it built 2-4 days before the end of the month. Someone with a birthday book will probably narrow it down even further.
        The birthday calender on the C1 registry website comes up with Dec. 31 1953, a bit off I'd say. Hope this helps
        PS The birthday book is available from the NCRS store, mine is on its way.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12695
          Oeps, small bug, it has been solved. It returns 05/24/1962 now as the likely build date.
          greetings,
          Rob.
          Rob.
            The Wisconsin on-line calculator is back up on-line at http://www.ncrswi.bizland.com/bday/bdaycalc.htm; follow the directions - it only wants the last FIVE digits of your VIN.
            Wisconsin Birthday Calculator
            • Mark #28455
              Interpolate tell Mike I got a 2 bit word too
              Interpolate is to determine a number between several data points, extrapolate is to determine a number outside the data points.
              HEY! all those years of school FINALLY paid off!
              • Dennis C.
                • January 1, 1984
                • 2409
                Yo Mark - Thanks, I stand corrected... *NM*
                • David J.
                  Infrequent User
                  • May 31, 2000
                  • 28
                  Thank you for all of your help guys.
                  David
