66 halo panel and trim moldings - NCRS Discussion Boards
  • John F.
    • July 31, 1999
    • 105
    At a chapter judging event I got dinged for the finish on the halo panel and trim moldings - judging manual says "full gloss" - mine were judged "too glossy". Any suggestions on the correct paint to achieve the correct level of full gloss?
    John Farren
  • Mike G.
    • January 1, 1991
    • 418
    Re: 66 halo panel and trim moldings
    John: suggest you first try dulling the gloss down by hitting them with some rubbing (not polishing) compound. You might have to blend in a little pumice powder, but probably not.
    If you end up repainting, then you get to experience the wonderful black art of "flattening agents"! also known as trial and error...
    • Wayne P.
      • August 31, 1975
      • 1025
      unbuffed lacquer will get you the right sheen.
      • Rob A.
        • December 1, 1991
        • 2126
        John,
        If you're going to repaint it, make sure you test the new paint over the old on a spare piece of plastic. Some paints, particularly laquers, will peel off the underlying paint, if it was enamel. Try plastic-kote semi-gloss. It is actually more glossy than the name implies, without being too much. Again, test it over your existing paint elsewhere first.
        • John F.
          • July 31, 1999
          • 105
          Thanks guys for the tips. Helpful as always.
          John
