'66 spinner cap red flag paint - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Can the spinner cap with the flags be removed in order to repaint the red on the flag?
  • Rich G.
    • August 31, 2002
    • 1396
    Re: '66 spinner cap red flag paint
    I'm not sure if I'm answering your question, but the spinner caps are held on with three hex screws. Then the insert with the logo snaps into the center cap from the back. The inserts are available from LICS, for one.
    Rich Giannotti 38594
    • Rob A.
      • December 1, 1991
      • 2126
      Rich,
      After removing the spinner, I see the emblem can be removed by grinding off the three aluminum rivet posts. Are the flags exposed at that point to repaint or are they behind plastic that can't be removed?
      • Rich G.
        • August 31, 2002
        • 1396
        Rob
        I think that is one piece. I don't know if it was painted, then over-coated.
        It doesn't look to me that you could separate it. The one I am looking at is a repro.
        Hopefully, someone else will chime in.
        Rich 38594
