C2:67 Mechanical Clock Adjustable? - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    Anyone know if a mechanical clock for a C2 is adjustable. Have been replacing the quartz movement on mine, with my original movement. Here they are side by side:
    I bench tested the original with a battery charger over last night, and found that it is running about 2 minutes slow in 9 hours. While I have it apart, I was just wondering whether there is a fast-slow adjustment.
    I remember years back that it did always run a little slow, and that's the reason I put the quartz movement in it. Maybe it's just the nature of the beast.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Gary S.
    • July 31, 1992
    • 1628
    Re: C2:67 Mechanical Clock Adjustable?
    Jerry, isn't there something in the owner's manual on this? I am struggling to remember the 66 manual I had a few years ago. IIRC, you turn the clock backwards 12 hours to adjust some small amount, perhaps a minute or so? CRS is striking here.
    Gary
    • Kevin M.
      • November 1, 2000
      • 1271
      Jerry,
      That's just they way they run. I have a NOS unit in mine and have to set it every time I drive the car. I called the rebuilder and they said if you want it right put in a quartz. Now the instructions say move the clock forward to adjust speed, this did not seem to change anything on mine. Good news I have my old garage neon clock right in front of where I park my car to reset the clock each time I leave.
      Kevin
      • Stephen L.
        • May 31, 1984
        • 3148
        Jerry, EACH time you adjust the clock MORE THAN about 5 minutes without letting the stem go back, the clock will adjust its movement slightly in that direction. So if you lose time at a rapid pace (or run fast) try adjusting the reading in at least 5 minute increments and then keep track of the change over a 24 hour period. It'll take a few attempts but you can get it pretty close. I believe this procedure is in the owner manual.
        Steve Lavigne
        • Kevin M.
          • November 1, 2000
          • 1271
