C3 Frame for all ages
  • Calvin Camara (38021)
    • June 1, 2002
    • 83
    I have been told that all c3 frames are the same and I can use anyone. Is this true?
    I am working on several corvette projects. My 1973 convertible BB, has some front frame damage so I have been keeping my eye out for a frame as a possibility. I thought I needed a 1973 frame since it was a unique year.
    thanks
    cal
  • Chuck Rice (32205)
    • May 1, 1999
    • 1434
    Re: C3 Frame for all ages
    Regarding the front frame section, I'll venture that your safe from 68 to 82
    Chuck
    • Howell Jaynes
      Go to corvettefaq.com and click on the "Suspension." button. Under selection of articles open up "C2/C3 Frame History." This will detail all of the evolutionary changes made from the frame starting in 1963 up to 1982.
      • Robert Eisner (41801)
        • April 1, 2004
        • 398
        Cal, Remember 4 speed frames do not have removable transmission cross members, as automatics do.
        Robert
        41801
        • M & K Perkins
          Here's the info from that site so someone can find this in the archives if the site goes down someday
          1963 Frame intro
          1964 Body mt brackets changed & gussets added to kick up area
          1965 Indent added to xmember due to larger engine pulley - slot added for side exhaust mounting
          1968 Rear xmember changed - height & location of body mounts changed - extra gussets added to rear kick up area
          1973 Body mounts lowered to accomodate thicker bushings
          1975 Provisions for energy absorbing bumber shocks added
          1976 Left side exhaust mount on transmission xmember deleted
          1978 Gas tank xmember changed - Rear xmember changed to accomodate new rear styling and gas tank location
          IN GENERAL
          1968-1982 Automatics has removable xmembers & the Manual Transmission Vettes had welded xmembers. The exceptions would be the 80-81 in which they were all removable
          Hope this helps
          M&K
          • Michael Ward (29001)
            • April 1, 1997
            • 4290
            This list is not complete
            or accurate.
            It is true that a '73 frame is unique, but earlier or later frames can be modified to suit (been there, done that).
            Mike
              • June 1, 2002
              • 83
              Re: This list is not complete
              Are the modifications exstensive.
              cal
