1966 Engine Question - NCRS Discussion Boards
  • Doug Wilkinson
    Probably a dumb question for Vette experts but how can I determine if my 66 was originally a Big Block? It now has a 1969 (non-vette) 427ci. It has the hood and emblems but those are easy to change. Thanks Doug
  • Jim V.
    • November 1, 1991
    • 587
    Re: 1966 Engine Question
    Doug, heres a few
    1) rear stabilizer bar mounted to rear of tailing arm
    2) rear differential half-shaft heavy duty caps instead of u-bolts
    3) 90 degree fuel line instead of 45 running to fuel pump.
    4) heavier front stabilizer bar (forget dimension difference)
    5) tach redlines....this helps sometimes
