C1 Fresh air hose
  • Garry Barnes
    C1 Fresh air hose
    There seems to be a lot of confusion about what the actual fresh air hose for the C1's look like in relation to the space between the wire, etc. I see that there is a new hose that someone is making that is advertised as how the originals were, yet I have seen for instance the '57 Sebring/Nassau car first hand and it has a very old faded hose and it doesn't resemble the current "new" one at all. It looks more like the one that has been avaialble for the last several years. What is the position on the correct fresh air hose by the Team leaders out there? Thanks.
    Garry 18531
  • Geoff C.
    • June 1, 1979
    • 1613
    Don’t know anything about the new repro
    However I do know the OEM no longer has the production equipment to produce an identical product to that of yore. (Yore: isn’t that a great word.) The old hoses I have seen had a spiral wire visible and rusting on the outside of the cloth covering. The OEM changed their equipment to conceal the wire inside adjacent strips of the spiral wound cloth. Unless you were to manufacture your own production equipment, I don’t think the old pattern will be duplicated. Even the cloth covered material is being phased out in favor of other synthetic materials. If you want original, I would not hold my breath.
    It’s like the old freon hoses. The old stuff was cloth inserted with two layers for strength. The new stuff is just as strong and half as thick with no cloth insertion. Once the machines convert to the new production material, seldom will you get them to go back. They call them repro, because they are not original.
    Geoffrey Coenen
    PS I am not the leader of any Team, however my favorites are the NY Giants, NY Yankees and Team Corvette.
    • Joseph T.
      • May 1, 1976
      • 2074
      Re: C1 Fresh air hose
      Garry
      Below is a picture of the heater air duct hose removed from the 57 Nassau/Daytona car. It appears to be vintage correct however..please remember this car was born as a heater delete and the heater was added after it was retired from racing. I suspect the hose is correct but..production cars mainly had black colored heater hose duct.
      Also pictured below under the old hose is a newer heater hose I bought from Corvette Central ( I think ). It looks very close to the old one..but appears to be only 4 1/8" in diameter as compared to the vintage hose at 4 1/4"
      You might also call:
      CARS Buick Parts..they sell heater hose cut to length in diameter sizes 1 1/2" to 5 3/8"
      www.buick-parts.com
      908-369-3666
      The heater hose I bought from Corvette Central seemed to be a little short and was difficult to get in place...which resulted in breaking it.
      Hope this helps.
      Joe
      • Geoff C.
        • June 1, 1979
        • 1613
        another picture of an old one
        Gary
        Wonders never cease. When I first had a batch of FA hose made, I contacted the OEM and gave them the GM part number and they ID’ed that as their “blank-blank” hose with a 3/8 pitch and 38” long. Don’t hold me to the 38” – as I’m going from memory – N CRS memory. In retrospect, perhaps I should have gotten a wider sample of old installed product. I assumed it was the same product. If it is ½ or 5/8 or ¾” pitch, perhaps that spec was changed in later years - post the actual 1962 assembly line use. I don’t know that answer.
        I actually grilled them about their specs, because in the 70’s GM sold this stuff over the counter, but it was too long. It was in the parts book and serviced in a 4 foot length, but that part number was different than the AIM part number. And you really cannot cut to a shorter length and terminate the end like they do. Plus if I was buying several thousand feet, I did not want all the waste and neither would the end user.
        When I visited Sin City (Atlantic City) for their meet in May 2005 I took some pics of a fresh barn find 1957. Note that it appears in this one that there are two spiral wire inserts, one internal and another external. In another that I think may be old and original, I saw a single external spiral wire – not really an insert since it was rusting outside the cloth. It’s still one of life’s mysteries.
        For those on the Top Flight Safari, how many points do the hunters take on this kill?
        Gary has informed me there is a hose for sale on ebay, but I need a link to click on cause I CRS how to take an ebay quadrillion digit number as in 4612778013 and convert it to a picture.
        Geoffrey Coenen
        PS These photos from Sin City are branded. Expose yourself at risk of
        Scroll to the fourth picture
        • Mike E.
          • March 1, 1975
          • 5068
          Re: another picture of an old one
          Geoff--
          I don't know about 57's, but I've never seen anything like that one from the barn find on a 61 or 62. I've only seen the internal wire.
          That 57 barn find has, as you know the wrong upper radiator hose, etc. I wouldn't want to change anything to accomodate that hose unless we have a number of indisputable examples.
          Nice car--great find for that individual! Wish he wouldn't restore it!
          Mike
          • Joseph T.
            • May 1, 1976
            • 2074
            Mike / Geoffrey / Garry
            My old survivor 57 also had a flex hose upper radiator hose..and I am probably the one that put it on..looked just like the picture of the casade green barn find.
            What it reminds me..is that during the 70's and 80's..there were very few repro parts..and if your local Chevrolet parts department didn't have a replacement part in stock..for the old Corvette..then you did whatever you could.
            I remember the air duct hoses like the one on the 57 barn find..and they always reminded me of clothes dryer hoses...because they were so droopy! Chances are it is a replacement..using whatever was available. That is not a criticism.
            I have not seen the cascade green 57 barn find..but in your picture it looks like the air duct hose bracket is either too low or missing. Probably missing..because if you ever tried to change the passenger side plugs..after removing the air duct..you would scratch your arm on that damn bracket!
            Mike...I agree..I would prefer the car be left as is..
            • Garry Barnes
              Geoffrey, Joe and Mike,
              Thanks for your thoughts and insights on this. Geoff, the barn find pictures look VERY similar to the item on ebay. Im sorry but I don't know how to provide a link to this email or I would do it so that you can see what I am talking about. I do however have the photos that I mentioned to you earlier (on you email) that once I get home I could send to you and maybe you can post them for me. I can't say for sure that this new one has both the inner and outer wire, but it certainly is closer than the ones currently available. The real question is, which one is correct? Thanks Joe for the pics to show one that at least was put in shortly after retiring from racing. When do you figure that would have been?
              Garry
              • Geoff C.
                • June 1, 1979
                • 1613
                Re: another picture of a new "original" one
                Here is the link Garry referred to
                I personally have never heard of this seller nodak60. But who can argue with ebays method of identifying sellers or their own chosen face.
                If there was a genuine consensus of the ID, OD, length, pitch, wire OD, wire placement, left or right helix, I might be inclined to have these rerun differently because $65 for this would represent a worthwhile return for a short cloth dryer hose. Wow reserve not met.
                I don’t know if GM had several different suppliers for this cloth covered hose, however they did have several different sizes that were used and all are 3/8” pitch or that’s what OEM and original samples have shown. To name a few: 56-62 defroster hose, 63-67 AC duct hose, 68-75 defogger duct hose, 58-62 FI air cleaner hose. Over the years I’ve had all these different sizes rerun with nary a complaint of the pitch being wrong – except in the very recent past for the fresh air hose. I’ve also sold other sizes with the same 3/8 pitch to some 50’s Caddy and Buick restoration houses in Hemmings and they also never have asked for anything different that this stuff.
                I really don’t know where the basis of truth is for the pitch. For years I was an adherent to the 3/8” pitch camp, now I’m just as confused as everyone else as to whether I should bow and genuflect for 1/2” or some other size.
                Geoffrey Coenen
                PS Now you know why I retired.
                Ebay “original” hose
                • Jerry M.
                  • March 1, 1980
                  • 61
                  Hello: Let me explain everything I can about the Fresh Air Hose thats on the internet.I had the same problem as everyone else trying to find a good substitute for the original hose. So after doing a lot of research, I was able to get this hose specially made from an original piece of FA hose. This hose is as correct as possibly can be considering it is a reproduction.
                  This hose is 4" ID same as original and is made of black canvas material and is wire coiled on the inside. Many pieces of this hose are on the street all with positive responses.
                  Jerry Murphy # 3179
                  • Garry Barnes
                    Jerry,
                    Thanks for filling in the gaps on this product that you had made. As I have mentioned perviously I have seen these on some of the cars that I have judged and they do look well made, but I can't confirm the accuracy. This is why I started the thread. I would like to ask if you have more than one of these or if you have plans to have more made, but I don't want to violate any rules of the board. I am sure that if anyone is interested in speaking with you they can contact you off line correct? Thanks Jerry.
                    Garry 18531
