Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 '67 rubber inner fender splash shields... - NCRS Discussion Boards
  • Patrick T.
    • September 30, 1999
    • 1286
    two questions...first, the shields were stapled from the inside of the engine bay, with the two staple points out towards the wheel well, correct? Second, the smaller rectangular front and rear shields have two debossed lines running horizontally across them. Do these lines face towards the engine or out towards the wheel well?
    I've looked everywhere with no luck. Thanks in advance, PT
  • Phil B.
    • Today
    Re: '67 rubber inner fender splash shields...
    First point is correct - unsure on second.
    • Gary B.
      • February 1, 1997
      • 6979
      Patrick,
      I've just submitted an article to the Restorer on GM-created "damage" to the fiberglass area just aft of the passenger's side upper A-arm on '66 cars and I have a number of photos of '66 and one '67 that show a portion of the area that you talk about, viewed from the tire side. In these photos I don't see any indication of the lines in the small rear, rubber shield that you talk about, so I'm guessing the lines must be on the engine side, if there are there at all.
      Gary
      • Stephen L.
        • May 31, 1984
        • 3148
        Lines go in engine bay.
        • Patrick T.
          • 1286
          Thanks everyone. Yes, the '67 Judging Manual does specify 2 horizontal lines that you can see and feel on these four small splash shields. It's gonna be lot of work getting these stapled on tomorrow and I don't want the Judge to tell me later they're installed wrong! PT
          • Mike M.
            • 710
            I'm sure the workers on the line made sure every one was installed that way.
            • David K.
              • August 31, 2002
              • 62
              Can anyone tell me the dimensons of the shields? When installed properly how far up on the body are they or in other words how much of the shield hangs past the body?
              It is hard to tell in the assembly manual but at least the say how many stables to use. Thanks
                David -
                They extend down about 3/4" from the bottom edge of the inner fender.
