How to get a power steering pump apart? - NCRS Discussion Boards
  • jim #42767
    How do I get a power steering pump apart? Took all the bolts out and the pulley off, It just wont come apart. I am going to put a seal kit in it.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: How to get a power steering pump apart?
    place bolts in tapped holes in cast iron portion of the pump, clamp pump in vice using the inserted bolts to hold the pump, then use a fiberglass or plastic headed hammer to tap on the stamped steel part of the pump to free it up from the cast iron part of the pump. good luck, mike
