Transmission video - NCRS Discussion Boards
Transmission video
  • Mike N.
    • April 1, 2001
    • 110
    Transmission video
    Can anyone tell me where I can purchase the "ROY BRAATZ" video on how to rebuild a CAST IRON POWERGLIDE??
    OR any other video will do as well-
    Thank you in advance
    Mike
  • Jean C.
    • June 30, 2003
    • 688
    Re: Transmission video
    How about contacting Roy? He posts on this forum quite frequently and in fact he'll likely reply to your query.
    Charlie
    • Roy B.
      • February 1, 1975
      • 7044
      My Brother in Law has them "Dan"
      What's wrong with your's?
      • Mike N.
        • April 1, 2001
        • 110
        Hi Dan,
        Can you write to my email address: Pats57@adelphia.net
        with the information so I can purchase a video.
        I need to exchange the TAILSHAFT W/OUTPUT SHAFT on my 1957 powerglide. I now have a 1960 "tail shaft" ( too short ) and need to get the trans. back to original.
        I don't even know where to start. Good thing the body is off the frame. I plan on dismantling it while on the frame. Any suggestions greatly appreciated.
        Mike
        • Roy B.
          • February 1, 1975
          • 7044
          Mike
          I'm not "Dan" he's my brother in law, he has the Video I made, I looked at your trans pic. The Corvette tail housing having the three bosses can be changed easily in the frame. Do you have the right drive shaft?? Or heavy rear springs ?? The in-put flange sure is back from the trans quite a bit. And where you have the shifter mounted is off.
