57 posi value vs 60 posi value/Muncie?? - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    I have an early 57 posi in my 60. I found someone who has a 60 posi for sale. All things equal, is the 57 more valuable than the 60 or a wash? He wants $500.0 for his old posi.. My posi has no stamping on the pass./right side of unit. Is it an over the counter part?? The previous owner of 39 years, blew a hole in the old rear end and had it replaced at a Chevy dealer years ago. Also did all Chevrolet muncies in the 60's have the VIN stamped on the transmission like Corvettes? Thanks Dick Gutman
    Re: 57 posi value vs 60 posi value/Muncie??
    Dick -
    Are you talking about only the housing (pumpkin), or a housing with a Posi carrier unit in it? The '57-64 Posi units were made by Dana, and there are virtually no parts available to service them; Eaton now makes a modern Posi unit/carrier to fit the C1 center section that is far superior to the original Dana unit.
    • Dick G.
      • May 31, 1988
      • 681
      John: I am referring to a complete pumpkin unit. I removed one 12 years ago. The way I remember it, is you pull the outer axle shafts far enough out to clear the removal of the center complete pumpkin. Sound right. DG
