9679137 What is it and where can I get one? - NCRS Discussion Boards
  • Mike
    I've been replacing the wiring harnesses in my '74 L48 4sp and I came across a box on the rear wiring harness. I have no idea where I can get one or what it may cost. Does anyone know what it does is my next question?
    I have pictures posted at:
    www.automotivegadgets.com/identify.html
    if you would like to see this piece. It's in sorry shape and definately needs to be replaced.
    Thanks in advance.
    Mike.
    • 43193
    Re: 9679137 What is it and where can I get one?
    Mike-----
    The part you seek is the ignition interlock logic control module used on 1974 and 1974 Corvettes. If I recall correctly, this was the system used on those year cars which prevented you from starting the car unless the seat belts were fastened. It was used on many 1974-75 GM models, not just Corvettes. Most were promptly disabled making the part about which you inquire superfluous. That's probably why your deteriorated part caused you no problems; the system of which it is a part was long ago disabled on your car.
    GM #9679137 was the original part number for this component. That number was later discontinued and replaced by GM #9736651. The latter part number was discontinued many years ago, too. If you really feel that you want to replace this part, call Southside Automotive at 612-727-2404. This part went out of the GM parts books at about $60, but I'll bet that Southside has VERY LITTLE call for this item and will make you a good deal on it if you really want one.
