Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
66 Restoration Questions -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Restoring a 66 Big Block. What is the correct way to align the Alt. with the power steering pully? The Alt. needs to come forward about a 1/2 inch in order for the pullys to line up tp put belt on.
Are you sure that you have the correct alternator pulley? There is no adjustment built into the alternator mounting system to correct for this kind of misalignment. Usually, the problem is caused by one or more incorrect pullies. Your power steering pump pulley should be ok. Only 1 pulley was ever used for big block in Corvettes-----a cast iron, 2 groove pulley of GM #3878245.
The alternator pulley for your application (unless you have C-60) should have a "built in spacer" on the inner side.
Assuming you have the correct mounting brackets - you need a 427 PS pulley which is offset toward the front for proper alignment. This pulleys are repro'd and easy to get from most Corvette restoration suppliers
I know I have the correct P/S pully and brackets for the BB. I will check the alt. pully. If anyone else has any ideas that would help me please reply. Thanks Guys
Had the same problem as you on my 1966 Big Block and it was the Alt. pulley. The correct PS Alt Pulley has a built in spacer that is almost 1/2 thicker then the non power steering pulley.
