Rear leaf springs - NCRS Discussion Boards
Rear leaf springs
  • Bob M.
    • June 30, 2004
    • 20
    Rear leaf springs
    Where is the best place to purchase a new 9-leaf spring for a 66 BB?
    What is a ball park price?
    Bob
  • Kent K.
    • December 1, 1982
    • 1139
    Re: Rear leaf springs
    Bob,
    Try Eaton. Don't know about 9-leaf springs (or the cost) but their 7-leaf spring for my '67 looks very close to the original and performs correctly.
    Regards, Kent #6201
    Kent
    NCM Founder - Member #718
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12695
      Eaton sells a nice replacement. You have to ask them to provide the leafs and liners seperated (not assembled) since you do want to paint them in the gray (zinc) color. That saves you removing the melted liners from the leaves (a lot of hard work I can ensure you). The package is slightly thicker than the original setup (1/2") so you might need longer bolts (I didn't but my bolts were not original).
      greetings,
      Rob.
      Rob.
      NCRS Software Developer
        All-----
        I agree, too. I believe that the current Eaton replacements are the best thing available today. They are not perfect but they are the best thing available. This includes both the 7 and 9 leaf springs.
        Someday, when "Hugo comes around" we might have a better and more correct spring available.
        • Bob M.
          • June 30, 2004
          • 20
          Thanks for the info. Will try Eaton.
          Bob
          • Rob M.
            • April 30, 2003
            • 657
            Re: Thanks
            Bob,
            As others have suggested, Eaton is the best best for a new replacement. Here is their contact info:
            Also, as Rob stated, order it disassembled and then get the correct paint and a set of liners from Quanta http://www.quantaproducts.com/privacy.asp to finish it up. This is if you are planning on having it judged.
            I just put a 9 leaf Eaton on my SB 66 a month or so ago and I'm very pleased with it. The cost was about $200 including shipping etc. but I've heard they just raised their prices.
            Good luck,
            Rob
            Rob
            '66 327/300 Regional Top Flt
            '08 6 speed coupe
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12695
              Re: Thanks
              Please also note it will have a slightly higher wheel height (app. 2 inches, 5 cm.) Longer bolts (on the left and right) can undo this.
              greetings,
              Rob.
              Rob.
              • Rob C.
                • August 31, 2004
                • 144
                Re: Spring, Rob M
                Rob,
                How mutch longer on the bolts will take out 2" ride hight?
                If you can remember I replaced my spring with an Eaton spring about 2 months ago and mine is riding about 1 1/2" to high. Orther wise the spring is great.
                Just put a full tank of gas in it and spair tire I hope it will settel in a little more.
                Rob
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12695
                  Re: Spring, Rob M
                  Rob,
                  I guess 2 inch longer bolts would do the trick for 2"lower ride. the angle of the bolts is minimal so it works out nearly 1 on 1.
                  PS The spare tire (and tank with gas) do make a difference, but not much.
                  greetings,
                  Rob.
                  Rob.
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12695
                    Re: Spring, Rob M
                    See also attached picture for the new ride hide using the standard bolts.
                    greetings,
                    Rob.
                    Rob.
