If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I'm working on a friend's door with power window regulator and the motor is separate from the regulator. Is there a procedure out there for properly mating the motor to the regulator with the appropriate spring tension? The car is a 1976 coupe. Also, are the rollers of the regulator the same for power versus manual regulators? Two of the rollers are broken off and it seems only the outer portion of the rollers are affected. Does someone sell roller parts so I dont have to replace the entire roller but only the outer wheels to the rollers?
Yes, Paragon sells replacement rollers for both the window channel (11514) and the regulator (12030) and packages components in logical kits as well. Roller components are the same for PW and manual. As far as installing the PW motor, see your copy of the chassis service manual and PAY ATTENTION to the book's details. If the counterweight spring lets go while your fingers are in the regulator area, you might wind up seeing a hand surgeon!
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
