Is there a way to tell if an ashtray is original or not on a 63 corvette? and also isn't there a "p" or an "o" somewhere on the lightswitch in a glovebox to tell if it is original as well? thanks for any input.
63-ashtray & glove box light
Re: 63-ashtray & glove box light
Joe, which one is the 63??? They both have AAC stamped on the other side.
The one on the left.. They are different..
Harry
Attached Files- Top
Joe the one on the right was in my 63 when I bought the car 9 years ago. The wear and tear on the outside and the typical discoloration on the inside from cigarettes makes me believe it it an oldy and a goody.
Let's see if others comment on the originality.
On the glove box light, do you have a picture to post? I hate to pull mine out.
Harry- Top
Joe,
I agree with Harry. The one on the left in his pic is the correct style for much, if not all of the 63 model year. The design with the double/split tabs replaced the single tab design and continued through the end of the C2 run.
I have no idea when the actual change occured in production and the part number remained the same for both designs.- Top
