C1 pinion seal - NCRS Discussion Boards
C1 pinion seal
  • Howard M.
    • June 30, 2000
    • 124
    C1 pinion seal
    I need to replace the pinion seal on my 60 but do not have the flange holding tool that is used to counteract the loosening(or tightening) torque to remove or install the flange nut. If I use the internal gear set to withstand the nut torque (with both wheels on the ground), am I going to break or damage anything inside the differential.
    Thanks for any advice
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 pinion seal
    No! but replace the nut with a new one and torque to specks
