LT-1 Ignition/Heat Shields - NCRS Discussion Boards
  • Steve B.
    • July 31, 2002
    • 51
    I'm finishing installing the spark plug heat shields/ignition shields back on my '72 LT-1. I've got the AIM, but I'm still a little confused on exactly how everything goes together("V" shields, inner and outer shields). Is there another source that someone can recommend with diagrams or photos of these? I found some information in the archives here, but I just want to be sure. Only want to do this job once!
    Steve
    1994 ZR1 Green / Beige
    2009 Cyber Gray / Red Coupe
  • Phil P.
    • April 1, 2006
    • 409
    Re: LT-1 Ignition/Heat Shields
    use a paragon or ?? catalog compare bothe should be able to figure it out---i think lt1 only used 5&7 6&8 plug sheilds only---some one out there will add more info
