Removal of Water Spots - NCRS Discussion Boards
  • jim34671
    What is the most effective way to rid my car of water spots?
    I came across a multitude of these all over the body of my '70 just recently.I can only attribute them to possible lawn sprinkler as it has never been out in the rain.It is a 2 year old professional lacquer paint job in Donneybrook green with a coat of clear on top.
    I gave it a go using Meguiar's No.2 by hand application,but still circles evident.Is there a preferred product out there?
    What are my best options to get rid of these?
    At what point do I seek a shop to do it?I'm extremely frustrated with this.
    Thanks all,
    Jim
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Removal of Water Spots
    Try 3-M Finesse It. Hand rubbing usually works.
    • Clem Z.
      • January 1, 2006
      • 9427
      try white vinegar *NM*
      • Terry F.
        • September 30, 1992
        • 2061
        In a bad situation I have used "lime away." But try a clay bar. I have hear that they will pull them off. Lucky for you the clear coat is there. Terry
        • Alan Drake
          Try some of the auto detailing sites.
          I known that autopia-carcare.com addresses the subject. Go to home page, on left side select "Detailing How-to" then "Paint Polishing Clinic" 1/2 way down. Under that screen is a section called Water Spots - read that. Note it mentions the white vinegar method.
          • Rob Dame
            This water spot remover from Pro took the spots off my daughter's car with ease
            Professional quality auto, RV, marine and aircraft waxes, detail products, supplies, equipment and more since 1935!
            • Michael H.
              • January 29, 2008
              • 7477
              I Agree With Clem.....
              ..... The white vinegar should easily remove mineral deposits (water spots) from the paint surface without removing any paint material. If not, it's possible, or likely, the spots are actually coming from within the color or primer. If the primer surface was washed with hard water and allowed to sit/dry with water drops, the lime rings that result will eventually work their way back to the surface of the paint. I know this to be true..... from experience, unfortunately.
              • Clem Z.
                • January 1, 2006
                • 9427
                most likely white vinegar as it says mild acid *NM*
