Stupid Tow Question # 1 - NCRS Discussion Boards
  • Jim S.
    • September 30, 2003
    • 77
    OK, I have my 20' enclosed trailer and am getting it ready to use for the first time with the weight distributing hitch ect.
    I know I need 10%-15% tongue weight on the hitch.
    I obviously don't have much choice of where the C2 will sit over the axles but there is a couple of feet toward the front of the trailer.Once I get the correct location, I will bolt a stop block to the floor.
    What is the easiest way to determine how much weight is on the tongue when loaded short of finding a commercial scale.
    Jim
    Re: Stupid Tow Question # 1
    Some ordinary bathroom scales range to 300-350 lbs and that should be within your target for tongue weight. Use the trailer's jack screw to lift the tongue above a 'stand' holding the scale and slowly take 'er down onto the scale for a reading...
    • Lyle24961
      Check an RV site for a way to double the bathroom scales range if needed.
      Lyle
