Did all 71 cars come with smog system,I read cars in some areas did not require it
71 LT1 smog
Tags: None
Not quite true...
In '71, ALL engine configurations were equipped with CEC (Combined Emissions Control system, the carb idle solenoid and its relays), and the VRS (Vapor Recovery System, charcoal cannister). But, the AIR (Air Injection Reactor, smog pump) was NOT installed on base engine SB cars nor on LS5 BB engines...- Top
Re: Not quite true...
There's no such thing as a "smog system". The Air Injection Reactor (AIR) system an other systems that Jack referred to are "emission control systems".
"Smog" is the result of photochemical reaction of emissions with sunlight in the atmophere.
Duke- Top
Duke-----
To be even more correct, AIR is an EXHAUST emissions control system. There are, of course, other emissions control systems on the car. The PCV system is a CRANKCASE emissions control system. EEC is a FUEL VAPOR emissions control system.In Appreciation of John Hinckley- Top
