I'm looking at the scoring sheets and I'm confused about two items. In the mechanical section 10 it lists "Ignition shielding" and "Heat shields" as separate items. The Distributor shield is list in a different section.
Does the Ignition shielding refer to the shielding over the spark plugs?
Does the Heat shielding refer to the 'U' shaped shielding behind the exhaust manifolds/pipes?
Thanks for your help, Bob
