Would a diff date code of "C44" be reasonable for a car built May 18, 1964? Thanks. Gary
1964 differential date
Yes
How does this compare with the differential assy date stamped on the bottom of the case ? Sometimes, the carrier casting date (which you quote, March 4th, 1964, located below the left hand output yoke) can be up to 3 or 4 months ahead of the vehicle completion, depending on rarity of the ratio (ie. its demand on the assy line).- Top
