I am in the process of disassembling my 65 front end and need some advice on safely removing the front control arms and front coil spring. I have used a pickling fork before but as a result of some research in the archives on less damaging procedures I am interested in other methods.
1. There whas a Dec 05 which involves a two hammer approach to freeing the top ball joint from the knuckle using the downward force of the spring coupled with some liberating whacks with a BFH. This makes geometric sense but, how do I seperate the lower ball joint from the knuckle?
2. I am also interested in other safety measures in dealing with the compressed spring. I have taken past posters advice by compressing the spring upward using two thirds of an internal spring compressor (treaded rod and one hook) routed up through the shock tower hole. This is a nice compression technique. Note that the motor is already out of the car and the springs are therefore fully sprung, so using the car weight to compress the spring is not an option; not to mention the car is up on a kwik lift. The pic shows the threaded safety cable through the spring up around the front crossmember. This is ok until I have to lower the lower control arm to remove the spring.
Anyhow...your advice is appreciated.
