68 Oil Filter , PF-25 or PF29 ? - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Just received final word
    Below is the reply I just received from Chuck on this issue.
    Now I must find a PF-29
    Kurt,
    The correct filter is the PF29. Until the manual is revised we will accept either the PF25 or the PF29.
    Chuck Berge
    • Dick W.
      • 10483
      Re: Just received final word
      Kurt, if you are not going to show in FL there is a slim possibility that the PF-29 might be out by the next Regional
      Dick Whittington
      • Kurt B.
        • July 31, 1996
        • 971
        Thanks all. Picked up a PF-29 tonight *NM*
        • Don G.
          • March 1, 1989
          • 251
          Re: 68 Oil Filter , PF-25 or PF29 ?
          As further evidence that the PF-29 is correct for the the 1968 Corvette, I have an AC Filter Catalog dated January, 1969 that specifies both the PF-29 and PF-25 for the 1968 model while specifying only the PF-25 for the 1969 model. This suggests the PF-29 was original equipment on the 1968 model and was superceded by the PF-25 in 1969 when the PF-25 became original equipment on the 1969 model. As Joe points out, early 1969's may have used PF-29's but no documentation has surfaced to my knowledge.
          • Kurt B.
            • July 31, 1996
            • 971
            Also, in the last few days I saw a close-up picture of a PF-25 and stasmped on the side of the PF-25 is said that ut reolaces or supercedes or something like that the PF-11 and PF-29 so clearly the PF-25 came AFTER the other two.
            Kurt
