Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I bought new springs for my 69 427, and they came powdercoated. I want to remove all of the coating, but the stuff seems impervious to aircraft stripper, acid, and sand blasting. Is there a chemical out there that will do a good job of removing it? Thanks for the help. Mark
I powdercoat a lot of things for protection. Once protected, scuff them up and apply whatever paint over you want. I have used many different types of paint and not had any lifting problems. If you have already applied aircraft stripper, be sure to get it all off.
Eastwood sells a stripper that works. It takes several coats, but worked on a part that didn't come out correctly. You put it on for around 1/2 hour at a time if I remember correctly.
