Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 powdercoat removal question - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I bought new springs for my 69 427, and they came powdercoated. I want to remove all of the coating, but the stuff seems impervious to aircraft stripper, acid, and sand blasting. Is there a chemical out there that will do a good job of removing it? Thanks for the help. Mark
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: powdercoat removal question
    Sand blast or burn it are the only two methods I know of.
    • William B.
      • April 30, 1975
      • 939
      I powdercoat a lot of things for protection. Once protected, scuff them up and apply whatever paint over you want. I have used many different types of paint and not had any lifting problems. If you have already applied aircraft stripper, be sure to get it all off.
      • Phil B.
        • Today
        Eastwood sells a stripper that works. It takes several coats, but worked on a part that didn't come out correctly. You put it on for around 1/2 hour at a time if I remember correctly.
