an someone suggest a reliable person or business to install stainless sleeve in original 65 PB Master Cylinder? Thanks!
C2 Master Cylinder Resleeve
Tags: None
Re: C2 Master Cylinder Resleeve
If you are going to use DOT 5 fluid, White Post will NOT warranty their work. I have switched to Brake & Equipment Warehouse, 455 Harrison St, Minneapolis, MN 55413. Speak to Rob at 800-233-4053. They have done about 6 masters for me and probably 20 wheel cylinders without a hitch. I found their work less expensive and the quality better than White Post. I had several masters sleeved and rebuilt by White Post with parts left out of the rebuild. Old Billy wouldn't stand behind their work so I won't use them again. I also understand that White Post outsources their work to someone in Florida.
White Post uses brass whereas B&E uses stainless.- Top
Thanks for the info. Thats just what I needed before I made a mistake.- Top
Called Ron. Nice guy and very reasonable! I got to go box up. Thanks for the info! Mike- Top
