Re: 70 C3 suspension fastener finsihes
Expert?...geee thanks! Nah Chuck to be honest I'm still an apprentice
Seriously though, I have to give credit to those on this forum that have helped me with my plating problems as well a particular individual on the Caswell forum. If it wasn't for the help from these guys I'd still be spraying my hardware silver, grey, or black!
Travis, I know the kits seem expensive and I hummed and hawed for quite some time before I bit the bullet but I have no regrets. You don't really appreciate the ability to plate your own parts until you NEED only one particular piece done! It's still easier and if you factor in your time cheaper to send the parts out to a commercial plater, however if you want quality results you should still prep them yourself even if you do send them out. The main benefit of doing it yourself is convienience and piece of mind that something won't get lost. Convienience can't be stressed enough because as Chuck says you will always miss something. Commercial platers also will not plate assemblies such as fuel pumps and vacuum relays so the only way to do this is to do it yourself.
As far as the black/grey parts they are cheaper and easier to do but once you get hooked on them you'll probably want to do cad/zinc as well! I can't comment on the Eastwood blackening kit because I bought my solutions from Grant Wong and was more than happy with them. I have heard though that the Eastwood zinc plating kit is not near as good as the Caswell one so if you choose to plate zinc in the future go with the Caswell one and make sure you have a large enough power supply for what you intend to plate!!!
