Hello from Berlin
I have a problem with a TPI Engine. The Car hast not run for more than 6 years.
And now the engine will not start. I check all the pules and voltage also I check the fuel pressure. Everything thinks OK. I think the injectors stick and the fuel can not run . Must I remove the hole Injectorunit incl. the Manifold ?
or have somone a better Idea.
Thanks Berndt
Thanks Berndt
