Spark Plug Wire Length 327 - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 975
    Help!! I have lost the sheet that comes with repo plug wires indicating what the correct length by number. Anybody got one to share?? Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: Spark Plug Wire Length 327
    I don't have all my notes Jim, but for '63 at least, cyls 1-3-2 were all the same length, the next longest is 4, 5-6 are the same length, 7 and eight are different and shoult be easy to pick out by the fit.
    Bill Clupper #618
      Mike -
      My notes show the following:
      #1 - 49"
      #2 - 49"
      #3 - 49"
      #4 - 45"
      #5 - 32"
      #6 - 32"
      #7 - 28"
      #8 - 26"
      • Wayne M.
        • March 1, 1980
        • 6414
        Jimmy --- you don't mention what year, and I assume you are referring to "with U69". Noland's Vol 2, page 166 (1963 section) calls (for L84, w/90 degree boots) cyls # 1, 2 and 3 @ 45.7 inches (centerline-of-terminal to centerline-of-terminal. Cyl # 4 unique @ 42.3". Cyls # 5 & 6: 28.8 inches; Cyls # 7 & 8: 24.2 inches long.
        Chev P & A 30 catalogs in mid-'60s for 327's are not much help, other that to show '63-64 w/F.I.; cyls # 5, 6, 7 & 8, all 28" with 90 degree boots. All other catalog dimensions refer to big blocks.
        • Christopher R.
          • March 31, 1975
          • 1599
          Just did this. And I kept the instruction sheet. And I was able to find it.
          1. 49.0"
          2. 49.0"
          3. 49.0"
          4. 45.0"
          5. 32.0"
          6. 32.0"
          7. 28.0"
          8. 26.0"
          The number above is the cylinder number. The length is that of the wire, terminal end to terminal end. Note the terminal end of the plug end is the centerline of the boot. The sheet says all lengths are +/- 1/2"
          This is for 1958 to 1974 small block Corvettes (and Chevies).
          • Jimmy G.
            • November 1, 1979
            • 975
            Thanks to one and all
            • Brad K.
              • August 31, 1990
              • 414
              Jimmy,
              I'll add a little bit to the confusion. For my '58-'60 283. (which ought to be the same) here's what the "Lectric Limited" folks say:
              1-48.5"
              2-47.5"
              3-48.5"
              4-45.0"
              5-30.5"
              6-32.0"
              7-28.0"
              8-26.5'
              When I actually measured them, some deviated from these measurements by as much as 2 1/2"
              • mike cobine
                You should try generic wires. The lengths are all over the place. I think some I have were designed for a straight eight by the length.
