'62 oil pressure - NCRS Discussion Boards
'62 oil pressure
  • Terry R.
    • March 1, 2005
    • 359
    '62 oil pressure
    I think I am running excessive oil pressure(50lb @ hot idle). Tested pressure with good test gauge,same reading,relief valve on pump must be bad, replaced pump with standard pump, same pressure,I can't find a spec for normal pressure, any ideas? '62 300 hp. Thanks
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: '62 oil pressure
    Terry,
    I believe the oil pressure spec on 300HP is 45 PSI at 2000 RPM. The oil pump in my 63 is Melling M55 and the car idles when hot at about 15 PSI oil pressure and looks to be close to 45 PSI at 2000. Verify that you have the standard pump and start there.
    • Terry D.
      • May 31, 1987
      • 2690
      Is the engine a fresh rebuild? Was pressure always this high? My 340hp runs about 20 to 25 at hot idle and 35 to 40 down the road. Maybe you replaces a high powered pump with the same. Did you switch oils or filters to cause this?
      • Terry R.
        • March 1, 2005
        • 359
        Engine has about 10,000 miles on it,oil pressure always been high. The oil pump is a m55. Maybe clearances real tight but no problems with it mechanically. Thanks
        • Timothy B.
          • April 30, 1983
          • 5177
          Terry,
          I think Melling makes a M55 that's high volumn. It may have a letter after it in the part # and I'm sure someone will correct me with the accurate info. Check the archives on this, I believe there was some discussion a while back.
          • Terry R.
            • March 1, 2005
            • 359
            Tim , The tag on the pump has hm55 and 95283b maybe were on to something. Thanks
            • Dale S.
              • November 12, 2007
              • 1224
              Terry, When I had the parts store, we stocked Melling oil pumps. There was a M-55(standard),an M-55HV(high volume),and I believe a M-55HP(high pressure).I dont know if there was a difference on a tag or not, but I do know that we once in a while sent out the wrong one in the right box. Dale
              • Terry R.
                • March 1, 2005
                • 359
                After extensive research in the Archives(a wealth of knowledge with the click of a mouse) I must have the wrong spring. Thanks everyone.
