Can anyone provide me some measurements? To the center of the acorn nut that holds the shifter cover on, could I get measurements from the floor and then the base of the seat separator when it meets the trans tunnel? I'm trying to locate the center of the shifter hole so I can glass in a replacement piece I have on order. Mine was hacked up for a 4 speed when I got the car. If I have these two measurements I should be able to get the new part in the right location.Thanks in advance, Mike.
53 -55 trans tunnel help
Tags: None
Re: 53 -55 trans tunnel help
Roy, that would work if I had the linkage. That was missing with all the other transmission parts. I palnned on fabricating one once I had everything put back together. If I know the measurements, I can fix the trans tunnel while the body is off the frame, then fab the linkage or buy one.
Mike- Top
When you rec the peice
you will see there is only one place for the shifter to go
I am sure we can send you pic of one without the carpet
you will see what I mean.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
1957 Corvette - FI 3 sp - Black and Silver- Top
