If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Unfortunately, the front half contains the shaft that the springs and brushes interact with, so when you unscrew it from the back, the removal of the shaft allows the brushes and springs to pop out. That said, bascially that is what I am proposing to do with the only problem being resetting the springs and brushes, and re-attaching the pulley and fan.
Kirk:
If you remove the large nut at the front and the fan, pully, etc, The front half shoul come offclean, shouldn't it? The front bushing and retainer would be attached to the front half. The shaft, stator, and all other parts would remain in the back half. It's been a long time since I have seperated one of these so I might be forgetting something.
Jeff
How do I tell? It looks exactly like your picture except where the "hole" is there is a slot. On the top right flat surface above the ground bolt is stamped "1100616" over what looks like "2 R(B) 19". On the "resistor" or at least that's what it looks like from the inside (the circular region to the left of the center circle where the shaft seats inside) is stamped "7959455 DR 5MF". Does that help in identifying it.
The front half has "1100750 61A" over 6M15-12VNEG", which should be the correct numbers for my April build 1967 327 with AC.
No the rotor and shaft come off with it. Mine is stamped inside "1958565" with large "9" above it and small "F" on the opposite side. Inside of the face is stamped "sectioned circle CFD" and "11959918".
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
