Diaphram type clutch pressure plates, AKA ankle breakers, even when adjusted correctly, which is your problem, SUCK! When launching at stop lights, on the way for groceries, these clutch/pressure plate combinations sometimes stick on the floor (at rpm) and fly upwards with great force unpredictably. If the pedal catches your ankle, serious injury results. I always use a borg-beck, long, or combination style pressure plate. McCloud makes some really high quality versions as does centerforce.
Varooom!
Varooom!
