Re: Clutch Return or Not! - NCRS Discussion Boards
  • Dale Pearman
    Diaphram type clutch pressure plates, AKA ankle breakers, even when adjusted correctly, which is your problem, SUCK! When launching at stop lights, on the way for groceries, these clutch/pressure plate combinations sometimes stick on the floor (at rpm) and fly upwards with great force unpredictably. If the pedal catches your ankle, serious injury results. I always use a borg-beck, long, or combination style pressure plate. McCloud makes some really high quality versions as does centerforce.
    Varooom!
  • Dave - NCRS#24235
    I love Bellville spring pressure plates!
    I love 11 inch Bellville spring (diaphram type) pressure plate assemblies. In my 66, they provide great uniform clamping pressure with low effort - which is what is needed with the linkage in the low (fast shift) position.
    I have never owned an older Corvette with an over-center spring, but I would bet that the stock set up (with the engine and transmission correctly mounted and all linkage bushings replaced) would work fine. I drove and raced Chrysler products in the sixties, and they used over-center springs. The stuck-to-the-floor problem inevitably turned out to be a bad adjustment or a worn part - neither of which should be tolerated in a performance machine. - Dave
